ridemtraExplorerJul 01, 2017tandem axle equalizeranyone have an equalizer flipped over with the rear leaf spring below equalizer have both sides in the same position can this be returned to original position without total disassembly
IvylogExplorer IIIJul 01, 2017Jack on axle or end of equalizer bar that is correct and using a bar you can snap the wrong one back in place...it may go back on it's own.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,189 PostsLatest Activity: Jan 18, 2025
Related ContentTandem or single axleTandem Dually AxlesSingle or tandem axleF150 3.15 axle 10 speed equals 3.55 axle 6 speedTandem axle equilizer and shackle angles
