- MURPHY55347ExplorerHere
3MTM 76 High Tack Adhesive
3MTM High Strength Adhesive 90
3MTM Super Trim Adhesive
676 High Performance Spray Adhesive – Russell Products Bristol, IN
Bostik Supertak High Performance Spray Adhesive
Boring-Smith Super Bond 4H High Temperature, High Strength Adhesive
Spray Rite All Purpose Adhesive – Chem Tech, Inc. Bristol, IN
STA’-PUT IV Multi-purpose Spray Adhesive SP4M - TACC Rockland, MA
STA’-PUT IV Multi-purpose Spray Adhesive SP4H – TACC Rockland, MA
Stick Up Heavy Duty All Purpose Adhesive – Beaver Research Co. Portage, MI
Sta-Put 2001M Solvent Free Multipurpose Adhesive – ITW Plexus Construction Adhesives
WT-HS13 (Can) High Strength Spray Adhesive – Westech Aerosol Corporation, Port Orchard, WA
WT-HSC13(Canister) High Strength Spray Adhesive – Westech Aerosol Corporation, Port Orchard, WA - charlysmom_dadExplorerThanks for the ideas. I'll look into them all.
- GordonThreeExplorer
time2roll wrote:
I would use some spray-on contact cement.
x2 for a spray, that sounds like the easiest solution.
Another idea; a good outdoor fix-all tape, like Gorilla.
Clean everything with soap & water followed with isopropanol, and then tape the heating pad to the tank from one side to the other, so the tape is sticking to the plastic walls of the tank and the pad itself. - I would use some spray-on contact cement.
- MDKMDKExplorerI had thought about adding some sort of strapping around the tanks to keep them in place. On the to do list.
- downtheroadExplorerThere are lots of glue choices out there that will work great....Home Depot or Lowe's will have a good selection.
If you want it to to stay put, maybe consider a 2 part epoxy...JB Weld.
You will have to find a way to hold it up while it cures.
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 16, 2025
