pweekly's avatar
pweekly
Tank level indicator isn’t lighting up
Hi all. I have a 2005 Mandalay Motorhome and the control that shows the tank and water levels won’t light up when I push the switch. On that same panel is the water pump and that switch works and lights up. Any ideas what it could be? Bad switch? The fuses in the back all seem ok.
Thanks.
Trish
  • Thank you both. Turns out it was simple. Bad Fuse. Fuse looked fine too. Bought a set of new ones and am now good to go. For once, it was a simple thing.
  • I agree, the fuse would be the first thing to check.
    A bad switch is certainly a possibility. Sometimes you can tell by feel if a switch is wearing out, sometimes not so much. A loose or broken wire or solder joint in the monitor panel circuitry could likewise be another possible cause.
  • Probably a fuse. Most of the time you cannot tell if a fuse is OK by looking at it unless you take it out and look very closely. Even then it can be hard.
