klutchdust's avatar
klutchdust
Jul 19, 2014
Tapping into propane system for outdoor stove
My 09 Cambia has a 18 gallon propane tank. I have a free standing stove that I use for my wok. What are my options for propane. This coach has limited storage space so trying to avoid carrying a
typical 5 gallon cylinder.
  • wa8yxm's avatar
    wa8yxm
    bob213 wrote:
    Something like this may work. Google for best price...
    Extend-a-flow
    In my PUP and TT days.. That is EXACTLY what I used, works great.
    Now I live in a great mobile home,, I use the "Extend-a-Stay"
    Too bad Marshall Brass got out of that business, but another company has stepped up to the plate.
  • I added some more details to my message after you quoted it, and changed the link because the first link I posted also has a tank that is very very short, but the same diameter around as the bigger tank. I didn't want you to order the wrong one.
  • Bobbo wrote:
    I know it isn't what you asked, but I got one of these 1 gallon propane tanks. It is less than a foot in diameter and shorter than the 5 gallon tank.
    I like that. Thanks.
  • I know it isn't what you asked, but I got one of these 1 gallon propane tanks. It is 7.5 inches in diameter and 12.5 inches tall. It holds 5 times the propane of the little 1 pound bottles, and 1/5 of the propane of the larger 20 pound tanks.
  • Well no outside connection from the mfg.
    The grill is actually a two burner camp chef explorer. Large burners excellent for a wok. I can put a regulator in the line to decrease the pressure as if it was getting fuel from a portable tank, correct?
    Extend-a-flow
    This is what we have used for several years now on our Class A and now B+. Saves carrying a separate tank that takes up valuable room.
  • A lot of LP grills aren't designed to work on the 11" at the outside connectors. You can contact the mfgr of your appliance to see if it will work and/or if they have the right parts to make it work. Otherwise the extendaflow will give you full tank pressure, if that's what you need. Craig
  • RoyB's avatar
    RoyB
    Are you sure you don't already have a propane connection on the outside already of your 2009 Itasca CAMBRIA - Might be hidden by a small outside locked door - alot of RV's come with the outside BBQ setup... ??
    Roy Ken
Having RV issues? Connect with others who have been in your shoes.24,190 PostsLatest Activity: Jan 24, 2025
