professor95
Sep 04, 2010Explorer
byates wrote:
I think the answer lies in the quality of the breaker switch, not whether it is thermal push button, thermal/magnetic switch, or solid state switch.
Not to get into a long discussion, but this is a big issue with me. I DO NOT like the thermal breakers and never have. I consider them unsafe for use with generators. There response time to a fault or over current situation can be as long as 15 minutes before a trip. The more expensive thermal/magnetic responds in seconds to an over current situation or fault.
I tolerate the thermal push button breakers because I am generally feeding power into a breaker panel on the RV with magnetic breakers. I know they react quickly to faults.
You may or may not know that I also use a GFCI with any generator and have advised others to do the same. The reasoning is wrapped around the issues of neutral identification and bonding or choosing not to bond - the latter IMPO being much safer for a RV.
As an Electrical Engineer, Master Electrician and long-time teacher of electricity/electronics there are many issues concerning electrical safety with a generator people without such knowledge do not understand or simply ignore.
My comment/response was simply to point out that CPE's election to use a switch type fast response breaker over a push button thermal was a positive decision for personal safety.
I agree with you totally on quality materials. I simply hate cheap stuff that breaks or fails causing the frustration of replacement and the time and energy lost. I NEVER buy the 48 cent switches or outlets. I prefer to spend more and buy a quality specification or commercial grade device. Same is true for power tools, hand tools, lawn care equipment, etc. Cheaply made junk that breaks or falls apart is not a cost savings. I prefer metal to plastic whenever possible.
Not all items made in China are junk. But, that said, there are boat loads of junk being imported from China. You do have to be selective and have some trust/experience with the brand. As an example, Harbor Freight is a Chinese tool mecca. If you do not know what you are buying there beforehand it is easy to get junk. :) I love to shop in the store but am extremely selective about what I purchase.
