โMay-27-2010 02:06 AM
โMay-01-2011 01:32 PM
Hybridhunter wrote:
For me this gen is 100% for camping, so the whole experience of owning it for me depends on it's effectiveness and longevity. A lot of people waited for this product from CPE, I hope their is the typical large number of happy customers out there, who never post....
โMay-01-2011 12:59 PM
Hybridhunter wrote:
I still can't figure why my converter is tripping it, especially once I have it charging, and then it goes into bulk mode, and the generator still overloads, even though it does not sound like it is laboring.
MrRchitty wrote:
What was the charge condition of the battery or batteries?
MrRchitty wrote:
I am not sure how far back you read, but I had an issue with the Little Champ. I attached it to the travel trailer and the batteries were very low. The WFCO 8955 recharged the batteries over 5 hours. At the end is where I noticed a problem when I tried to operate the microwave and had issues with it going into overload and then smoked. It was promptly replaced. I have since replaced the batteries and have not had an opportunity to "cycle" the batteries and let the replacement Champ recharge the batteries. There are pictures of the WFCO scoped and its effects on the generators can be seen.....
MrRchitty wrote:
Otherwise, I have good luck with the Little Champ. Single items such as a shop vac, small compressor, small upright vacuum in the camper, 1100 Watt micro wave, 1000 Watt water heater on the TT etc....
I also added an additional circuit breaker on my WFCO 8955. The converter was pigtailed with another circuit on the camper not allowing me to turn just the converter off. Now, it has it's own breaker. It allows me more options to manage my power.
Again, thanks to the Professor!!
โMay-01-2011 11:18 AM
โMay-01-2011 10:24 AM
greenrvgreen wrote:
Well, I can understand Prof seeming to sock puppet for CPE,
greenrvgreen wrote:
However, CPE made a conscious decision to jump into the 2k pool, and at this point their product seems destined for third place. It is both slightly heavier and slightly less capable than the red or blue "2k" units. At the same time it is half the price, and appears better-designed and better-executed than the remaining "Honda clones".
IMO, the stackable design and the modular dual wiring are exactly the kind of category-dominating offerings I would expect from CPE. I have no doubt that they are busy incorpporating lessons learned into the design for the 3k. But I think that the economies of scale that worked in their favor with the (magnificent) synchronous 3500/4000 now cut against them.
Over the winter I had pretty much decided to make the plunge and pick up a Champion 2k. However at this point it no longer looks like a something-for-nothing proposition, the way the 3500 still does. The absolute lack of surge forgiveness is more or less a deal killer for me, at least until they fix this.
And $1000 for a Honda or Yamaha just seems like too much for a camping generator. I spent some time trying to dress up my CPE 1200 (synchronous) as a candidate for "main" generator, but it is just too small. I think the "perfect" size is the 1600/2000 inverter, and if CPE can get theirs to accept surges similar to Red or Blue, then I'll go for it.
โMay-01-2011 10:14 AM
DSchmidt_2000 wrote:
FWIW, the Yamaha EF2000is does talk about power factor. They have a chart in there derating the max wattage to be connected to their inverter generator. If I remember correctly the max wattage for a motor appliance is less than 1KW, not so much for the starting surge but due to the < 1 power factor.
Yep, here it is on page 20.
http://www.electricgeneratorsdirect.com/manuals/EF2000iS_manual.pdf
โMay-01-2011 09:45 AM
โMay-01-2011 08:21 AM
โMay-01-2011 06:37 AM
Hybridhunter wrote:
Not even a comment about the power factor professor? That reply sounded like a company statement. Hmmm
Realistically my converter situation is not even slightly outside of what the average user should expect.
โApr-30-2011 08:39 PM
โApr-30-2011 08:30 PM
โApr-30-2011 07:54 PM
PrivatePilot wrote:Hybridhunter wrote:
Do you have the updated control board?
No idea. I've no idea how to even check.
โApr-29-2011 05:36 PM
โApr-29-2011 08:54 AM
โApr-29-2011 07:21 AM
โApr-29-2011 07:06 AM
