Davidlee64's avatar
Davidlee64
Time for a new power converter.
I have a Parallax 7345 converter in my 2004 5th wheel. The PO decided that since it wasn't charging the batteries, the best thing to do was put a battery charger on them. I am looking at a PD4600 series upgrade kit. But, after looking at what is involved, I also need to do some wiring upgrades as well. In trying to figure out the wiring, I discovered a pair of red 8 or 10 ga wires going up into the floor about where the power center is. Both are hooked to the + side of the battery. Then there is a pair of similar size going into the wall. One is red, the other is pink.
I located the 10 ga romex from the shore power receptacle, and 10 ga romex from the generator. I don't know how the genny is hooked into the system, until I can pull out the converter and get an eyeball on things. I found a pair of red 8 ga or so wires next to the bed. One wire has black tape wrapped around it to indicate neg side, I presume. I love trying to track these kinds of messes down.
So after all is said and done, what would be recommended for the genny to power center hookup? An automatic transfer switch? Unplug the shore power before starting the genny? A simple disconnect so there is no feedback into the pedestal? I do want to be able to run the generator every so often to exercise it without damaging anything.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Jan 12, 2018
