jornvango's avatar
jornvango
Nov 26, 2020
Tire pressure
Our Casita has one axle. The tire on the left is a newer Hi-Run load range E with max cold psi 80. The tire on the right is an older (unused) spare Goodyear Marathon load range C with max cold psi 50.
Is there any recommendation for psi? I was thinking 50 psi in the Goodyear and 80 in the Hi-Run.
Just thought I'd check as I have never had two different load range tires on a trailer with different psi...
Thanks!
Having RV issues? Connect with others who have been in your shoes.24,239 PostsLatest Activity: Apr 25, 2025
