MEXICOWANDERER's avatar
Jul 31, 2016
Toad Roof Rack Mounts?
Car has no rain gutters. Making rack out if 1" square steel tubing. Full roof area with 6" high rail. All lightweight stuff goes up there. Bedding, 1" memory mattress topper, clothes.
But I need something to secure it to roof. (12) Riv-nuts?, door-openings clamps? Which type are universal fit? Much appreciated!
  • DrewE's avatar
    DrewE
    Yakima and other roof rack companies offer some generic kits, as well as vehicle-specific kits. The traditional approach, as I understand it, would be to attach a set of rails to the roof fore-and-aft, and then clamp legs to the rails where needed, and the crossbars or whatever to the legs. There often are also fixed leg mounts available.
    Here's Yakima's intro page on custom installations.
  • Rhino-Rack also makes cross bars for cars without rails. We bought a set to carry our porta-bote on the roof of the toad. Saved a few hundred dollars over going with the factory rails and cross bars.
    -Michael
  • Check out Yakima, they have racks that employ clips that are specific to each vehicle model.
    I have had good luck buying them used on eBay and they are of good quality and stay on.
    You might be able to work the clips into the rack you are building.
Having RV issues? Connect with others who have been in your shoes.24,345 PostsLatest Activity: Dec 11, 2025
