- BarneySNomadBlack, Red, White, Green.
You can purchase this adapter from Camping World to adapt to an old Dometic thermostat wiring. I left my old wiring in place and used it to connect the new thermostat to new air conditioner.
Barney
- Bob_VaughnExplorer
BarneyS wrote:
Go to the connector and tell me what color the 4 wires going into the connector and what color the 4 wires are coming out of the connector........Bob Vaughn wrote:
Shal36 wrote:
I am convinced that there is a design flaw and Atwood will not admit it .....they will not release a wiring schematic just a block diagram which does not show what color the wires are so it is useless to try to use that to trouble shoot. For instance it shows a connector with 4 attachment points but does not show what color the wires are going in an out of this connector....
The Atwood heater does not perform well. Fortunately, I bought the unit mainly for the AC portion. I found that the heater will not reach the temperature I want and will not keep it there, even if it’s not that cold outside.
I guess I am going to be the odd man out here. My Atwood 15000 btu works well in both air conditioning and heat pump modes. The fans do do some weird things on heat mode but it does warm up our 30ft trailer quite well and will hold the temp I set after a while.
Don't know if the following wiring diagram will help you or not. It does seem to show the wire colors.
Barney
- BarneySNomad
Barney
- imgoin4itExplorerMany folks are saying basically the same thing. Except for the 15,000 BTU Atwood acnd with heat pump every heat pump out there does a good job of heating an RV. The Atwood acnd unit is great on cooling, more air than some others, and in some cases more cooling than others. It will not however raise the heat in nearly any RV even when outside temp is at or above 45 degrees. It cycles on and off continually just like Atwood says and when some heat comes out it cycles off. I’ve talked to Atwood extensively and that is just the way it works. For heating purposes it is absolutely useless.. I trashed mine and went back to the Dometic penguin.
- doc_brownExplorer
2naEagle wrote:
As long as the temperature is above 45 degrees my Colmeman heat pump heats the trailer with no problem. Below that I run the gas.
Same on my Class A pusher. - Fulltimer50ExplorerI have found on my unit(not your brand) that the new style automatic thermostats will run the fan motor on low in the heat position, which is not fast enough to move much air for heating. I had to set the manual fan position to high to get it to work better. Works better but runs all the time.
Shal36 wrote:
I’m very happy with my Atwood and it’s cooling performance. It works much better and is much quieter than the old Carrier unit I had. If I remember, the 13k BTU unit does not have a heat pump but the 15K unit does. My interest was mainly in the 15k cooling. A heat pump for mild winter nights in Florida was a bonus. Since we are once a month campers, using the furnace is not a big deal.
Yes, I would be disappointed if I bought this and really needed the heat pump to perform well.
We went to Leesburg over Thanksgiving and the heat pump cycling all night and not heating the rv drove me nuts.....The compressor runs 2-3 minutes then shuts off then the fan cycles on and off for a while then the compressor comes back on .....During the summer the A/C was great....just disappointed in the heat pump.... - Shal36ExplorerI’m very happy with my Atwood and it’s cooling performance. It works much better and is much quieter than the old Carrier unit I had. If I remember, the 13k BTU unit does not have a heat pump but the 15K unit does. My interest was mainly in the 15k cooling. A heat pump for mild winter nights in Florida was a bonus. Since we are once a month campers, using the furnace is not a big deal.
Yes, I would be disappointed if I bought this and really needed the heat pump to perform well. - Bob_VaughnExplorerIf you do not like dealing with frustration then by all means do not purchase an Atwood A/C. I have spoken to various retailers of their products and they too are frustrated trying to get help from Atwood. So do your self a favor and buy some other brand....
Looking for advice before your next adventure? Look no further.25,202 PostsLatest Activity: Jul 21, 2026
