mesoman7
Oct 08, 2017Explorer
Toilet bowl wouldn't stop filling
Wound up with a flooded bathroom due to the toilet bowl overflowing. Fortunately it was fresh water and not the black water. Turns out the water was intermittently flowing without the flush being activated. Just a brief spurt, but with nowhere else to go it would eventually overfill the bowl. I shut off the campground water supply and open faucets to depressurize the lines. Switched to the tank and pump, since I could at least shut off the water. With the pump on, everything worked fine. No more water flowing until flushed. I did notice that the water pressure from the CG was much lower than from the pump. I am wondering if the low pressure was causing the valve to not close properly. Any thoughts?
It is a Thetford toilet, about 5 yrs old.
