swimmer_spe's avatar
swimmer_spe
Tongue jack clicking
I am not sure what kind I have, but it looks like a lippet.
Going up or down, it only clicks.
I was able to crank it by hand.
On Monday, I will be going in search of a new one.
The jack is at least 5 years old, as that is a long as I have owned the trailer. Any idea why it would just click with power, but by hand, it would still go down? No bolts are loose, and the battery is good.
  • Do you have the standby hand crank??? Yes I know it is not fun to use but has allowed me to continue the mission when my electric jack failed. I eventually lost my hand crank but was able to use a socket and ratchet or plier clamps to carry on.
  • Nv Guy wrote:
    Could be the slipper clutch let go. It limits the power of the motor by slipping, while you are the limiting factor with the hand crank.
    If I weren't using it within a week from now, I'm guessing it's fixable.
  • Nv_Guy's avatar
    Nv_Guy
  • capacitor wrote:
    swimmer_spe wrote:
    capacitor wrote:
    Wouldn’t the motor still spin?
    It is still spinning, but the jack isn't going down.
    You said clicking.
    The motor is spinning, but the jack does not go down. When I press the button, the motor sounds normal, but there is a clicking noise like I have hit the end of the jack.
    You said clicking.
  • Roll shear pin! cheap fix, but getting old one out might be pain!
  • Possibly a roll pin sheared off on the power side but not on the hand crank.
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 09, 2026
