cleojayco's avatar
cleojayco
tounge jack not working
I have power to the tongue jack because the light works, the battery is fully charged but the jack will not go up or down. Thanks for any input
  • Check the fuse, check the wiring. The light doesn’t draw much. If that doesn’t work, buy a new jack.
  • don,t take much to light the light, but get your crank out and move it a few inchs, or a bad ground ,try a charger on the battery see if it moves.
  • Mine "failed" a year ago, and it was just the ground wire in the jack motor housing.
Having RV issues? Connect with others who have been in your shoes.24,191 PostsLatest Activity: Jan 19, 2025
