โApr-26-2017 02:41 AM
โApr-26-2017 11:01 AM
โApr-26-2017 10:41 AM
06Fargo wrote:And with tpms you don't have to.
I use an air pressure gauge to check pressure. I also look at my tires at stops for anything stuck in a tread etc....I was all set to order one but you read these threads trouble with this trouble with that I put the money into steel casing tires instead.
โApr-26-2017 10:38 AM
fj12ryder wrote:06Fargo wrote:It would be okay if a tire blew and you had someone watching the monitors all the time. But how would the cameras tell you that you've lost 5 psi, and you're still losing air pressure? Until the tire failed I mean. No offense, but cameras are just a pretty silly idea.
Would a pair of cameras looking at the tires be less fuss than a TPMS?
โApr-26-2017 09:51 AM
fj12ryder wrote:About a minute. The monitor is constantly cycling thru all the sensors, and suddenly one will just show blank. Turning the monitor off and back on will clear it up...for a while.
how long does it take for the monitor to alert you to the fact you've lost contact with a sensor? Have you ever checked the time frame? .
โApr-26-2017 09:46 AM
2oldman wrote:How long does it take for the monitor to alert you to the fact you've lost contact with a sensor? Have you ever checked the time frame?fj12ryder wrote:With my EEz system the 5er sensors drop out all the time, even with a repeater. I think I'll check the batteries soon.
.. excessively long time between losing contact with a sensor and being notified of that. It can take up to an hour to be alerted that the monitor has lost contact with a sensor.
โApr-26-2017 09:45 AM
โApr-26-2017 09:32 AM
โApr-26-2017 09:25 AM
06Fargo wrote:Heavens no. TMPS is also a good way to check your tires before departing.
โApr-26-2017 08:02 AM
โApr-26-2017 07:20 AM
โApr-26-2017 06:56 AM
โApr-26-2017 06:25 AM
โApr-26-2017 05:40 AM
โApr-26-2017 05:08 AM
โApr-26-2017 05:03 AM
