dclark1946's avatar
dclark1946
Trailer brake wiring question
Duplicate post. Moderator please delete. I could not find the original and thoughtI had not posted.
  • They want you to make a tight right-turn and go back to the Service Department so they can fix it right. Pre-delivery PREP should have caught that right away. If it were me, I'd get on the phone and lie. Tell the dealer you tried to stop but ran over a crosswalk full of nuclear physicists. And would it be OK if you forwarded his home telephone number to all the lawyers and cops.
    If indeed sold with disconnected brakes, that really is an unforgivable act of negligence.
  • Typically (in my limited experience) the wires are run down one side and fed through the axle to the other side where they are connected to the brakes. If you are saying the passenger side brake wires are taped off, it sounds like someone took a short cut.Maybe the assembly line was backing up?
Having RV issues? Connect with others who have been in your shoes.24,374 PostsLatest Activity: Apr 08, 2026
