brulaz's avatar
brulaz
Trailer Electrical Ground/Frame and Solar
The negative terminal of the battery goes to the frame via 6ga wire.
And I think the AC ground goes to the frame when we're not off-grid.
I'll wire the MPPT controller with two 6ga wires going to the battery, or maybe the negative wire will stop at the frame as that's closer.
But the MPPT controller also has a "ground" terminal. Should I do something with that? I haven't run a ground wire from my solar frames either.
Rogue says to run a separate 10ga from the MPPT grd terminal to "a common location in the DC load center, and through a Ground Fault Protection Device (GFPD), to comply with NEC requirements".
What sort of GFPD are people using if anything? Could I just connect the grd to the neg wire in the load center? Or should i just ignore the Mppt grd terminal?
Having RV issues? Connect with others who have been in your shoes.24,371 PostsLatest Activity: Mar 21, 2026
