BFL13 wrote:
swimmer_spe wrote:
BFL13 wrote:
swimmer_spe wrote:
The load rating of a tire, does that mean the one tire can support that weight, or does it mean the axle?
I have a small boat trailer and I plan to go to camp with it loaded with gear inside. I just don't want to wreck the trailer or cause a blowout, etc.
The tire is a 4.80-8
One tire. A single axle with a tire on each side can carry two tires' worth of weight. (The axle itself might have a higher "weight rating" than the two tires, so go by the lower rating -usually the sum of the two tires is lower than the axle's rating)
Some weight is also on the tongue, so the trailer can carry more, but you have to know all the numbers to not go over what the trailer is supposed to be carrying.
Each tire is rated to 500lbs, so I can carry a max of 1000 lbs?
Somewhere near there. You ought to know what the axle is rated for to not go over that. Your trailer registration might have a weight limit specified there (in BC, a small trailer like that does).
You also have the tongue weight and what your towing ball and hitch can carry/pull as limits.
You can get a load range C tire in 4.80 x 8 tire, they even have them, Carlisle’s, at Canadian Tire.
They are rated for 745 pounds each. That would give you a much better safety margin, even on a light axle.
