BFL13
Feb 09, 2017Explorer II
I don't use the % SOC on my Trimetric, but I gather you must enter an estimated AH size of your battery bank so it has a baseline for "100%"
You need to get the batteries all the way full by SG using equalizing voltages or anything that works, and then re-set the AH count to zero to kick off the whole process.
Otherwise you are forever off on the AH count vs the un-loaded voltage wrt SOC observation. (like now)
Don't forget to disable the auto AH re-set (see manual) if you are on solar or you will get an un-wanted AH re-set every evening when it starts to get dark.
