So...this isn't really an RV specific question, as I've turned my TT into essentially a permanent tiny home, but I figured this was a good a place as any for a general knowledge base on propane appliances.
I swapped in an older model 20" Danby range - D545 W - which I cannot find any info for online, except for a handwritten pdf parts list. Called Danby, they were no help.
It's completely propane, no electrical connections.
The issue I'm having is that the oven has become very finicky, which I've narrowed down to either an issue with the heater pilot or the oven control dial itself.
It used to be that when I turned the dial to "oven", the heater pilot would engage to heat the thermocouple, so I'd leave it there for a minute or so, turn it to the desired temp and the oven burner would light.
Now the heater pilot doesn't engage until the oven dial is turned to 170, then the burner won't light unless the dial is then turned up to "Broil", and takes about 5 min.
The heater pilot is definitely not hitting the end of the thermocouple in it's current setting.
By turning the only adjustment screw I can find (on the oven dial mechanism) I can turn up the heater pilot, and the oven lights within 30s which leads me to believe the thermocouple itself is fine. However...I can't find a setting on that screw which will increase the burner pilot without the standing pilot going out once the oven is turned off. Some pics of the oven dial and mechanism, and pilot assembly. Any suggestions would be appreciated.
thanks
![](https://drive.google.com/file/d/1rhBzkx2cSyKsHOEL-H4j0s15ENVKO_oC/view?usp=sharing)
https://drive.google.com/file/d/14EyRVGgjVUH9oZwqO-7f-f25yQGOBrC9/view?usp=sharing
https://drive.google.com/file/d/18FZzZtLQy82XP8KGkShWfRl5qwfSnudz/view?usp=sharing
https://drive.google.com/file/d/1jO4PpzzA7aTQgEquYBeJpqRlaAbo5GVd/view?usp=sharing
