macattack_ga's avatar
macattack_ga
Troubleshooting an Onan 2800
We recently acquired a 1995 Roadtrek Popular 210 (chevy) with an Onan 2800 Microlite.
Generator cranks and runs very well. Makes power. Runs smoothly. But after about 3min it shuts down. It will start right up again and run for 10-20sec and then shut down again with just a little choke (actuated by my finger on the control arm).
I've disconnected the remote start/stop controller.... same issue.
Disconnected any electrical load.
Plenty of oil.
Fuel filter is good.
Fuel pump seems to work. It pumps fuel when I disconnected the hose... maybe it quits after a few minutes.
Planning to rig up another fuel pump to verify.
When shuts down, it doesn't bog/surge like it is running out of fuel... it sounds like it was switched off.
If it's not the fuel pump I'm guessing it's an issue with the ignition coil.
Any other thoughts?
Thanks!
Mac
Having RV issues? Connect with others who have been in your shoes.24,209 PostsLatest Activity: Feb 27, 2025
