NRALIFR
Jun 12, 2018Explorer
How close to the batteries will you be able to place the inverter?
I’m doing what you are wanting to do, though with a lower power microwave (950 Watts), a single group 31 battery, and a 1500 PSW inverter. Straight line distance between the battery and the inverter is less than 4 feet, but due to the route the cables had to take, a disconnect switch, and a CB in the circuit, the actual wire length is closer to 6 feet. I had to use “0” AWG welding cable to hook it up.
I’ve run the microwave from the inverter long enough to cook a frozen dinner just to see if it could do it. Most of the time though, if I need to use the inverter for the microwave my Yamaha 1000 is already running and will supply about half the current. The camper battery supplies the other half. I’ve run it like that for nearly an hour before the camper battery was down to 50%. The Yamaha can’t run the microwave by itself, which is why I installed the inverter.
Having RV issues? Connect with others who have been in your shoes.24,194 PostsLatest Activity: Jan 29, 2025
