Resoman's avatar
Resoman
Turn signal issue...
I have a 2013 Forest River popup with a turn signal issue. When headlights on the TV are off, the turn signal works fine. But when the headlights are on, the left turn signal jis hardly visible. When I crouch down a look at the tail light carefully, I can see that the turn signal filament is flashing, but it's overpowered by the regular tail light to the extent that it's effectively useless. The right turn signal does not have this problem, it works fine.
Is my problem likely wiring (which looks fine), the tail light fixture itself or the bulb?
Any thoughts?
Thanks,
Gary
  • wa8yxm's avatar
    wa8yxm
    Bad ground. one of the turn signal lamps.. When your headlights are off the parking lights are also off. The turn signal grounds via the other half of the lamp.. Head and parking lights on that path is not open to them.
  • You look specifically at where the lamp wire pigtail connects to the trailer frame
    OR
    If a butt connector is used with an extension, at the butt connector.
    Put a new wire end on where the ground wire connects to the frame. Then shine the frame with sandpaper until it is bright. I use KEPS NUTS with a screw. They are harder to come loose. Tighten the snot out of it. Then smear Vaseline over the nut and bolt both sides.
    Still dim with a problem?
    Replace the butt connector
    The issue is within the lamp's socket
  • Some tail/turn light assemblies have 3 wires; turn, tail, and ground. Some only have 2 wires, tail and turn, and use the metal frame assy as ground. And the metal frame of the light assembly is bolted to some part of the metal frame of the trailer since the trailer frame is ground back to the battery.
    If you have three wires, then determine which wire is the ground wire and trace it to where it attaches to the trailer frame. If only two wires, then make sure the light assy frame is clean and well connected to the trailer frame.
    I would also check the ground wire coming from your cord plug to make sure that wire has a good connection to the trailer frame.
  • Thanks, Pauljday!
    As a matter of fact, I had the tail light repaired in September and the job ticket says "found loose ground at the tail light assy, tightened loose ground and tested".
    Obviously, the problem is back. What do I look for in the wiring?
  • YOu likely have a bad ground/negative connection at or near the failing bulb.......including a corroded socket.
Having RV issues? Connect with others who have been in your shoes.24,199 PostsLatest Activity: Feb 18, 2025
