I have 2 digital LED TV sets. One in the bedroom, and one in the kitchen/living room. I have a Lava HD-2805 antenna, connected to a Winegard RV-7042 wall plate. Reception is very acceptable as is. The...
If you have swapped the TV's to see if the problem follows the TV or follows the connection and the kitchen TV still does not keep a good signal then you will know that you need to replace the TV. It's likely the tuner is not as good as the other TV's tuner or the connection to or inside the TV is damaged.
Having RV issues? Connect with others who have been in your shoes.24,192 PostsLatest Activity: Jan 26, 2025
