Carl_n_Susan
Oct 05, 2013Nomad II
I choose 3 degrees as an example because:
1. The resultant 5+ inches over 8' is obviously an excessive amount of slope.
2. Not all refers are mounted longitudinally. The rear kitchen models typical have the refer mounted transversely.
You will not be comfortable in a RV which is 3 degrees off level, much less 6 degrees.
