theoldwizard1
Apr 02, 2020Explorer II
wa8yxm wrote:
In house wiring (120VAC) WHITE is neutral. Black is hot (at least usually)
In automotive and electroic wiring Black is "Ground" Usually (not always).
Typically 120VAC wiring uses "Romex" (a black, a white and a bare inside of a sheath) and the wire itself is solid, not stranded.
12VDC wiring is usually single conductor and is stranded.
That bus bar with single stranded white wire is very odd !
Personally, I would pull as much of the wiring out as possible and START OVER !
