โSep-07-2019 04:12 PM
โSep-10-2019 06:44 AM
audiodane wrote:Learjet wrote:
sounds like you are on the right track, just remember that you will need to be able to turn the power off to connect and disconnect....sounds like the outlet will be below the panel...so that should make it easy.
Ohhhh, I *had* forgotten about that. Yes, easy enough to just post a big placard that says "STOP! Flip breaker off before plugging/unplugging!" ....
It would be kind of nice though if there was a drop-down cover at acted like a switch. Lift the cover to insert- power cut. Lower cover, power on. Lift cover to remove plug, power cut.
But until then, a big red stop sign placard hanging on the breaker box should be fine. My kids would probably love to make it for me, too. ๐
..dane
โSep-09-2019 08:06 PM
โSep-09-2019 11:56 AM
wnjj wrote:audiodane wrote:sayoung wrote:
Please don't use anything made by Siemens , its junk from my experience with their breakers/panels.
Oh, really? I had not heard this. Hmm. Okay.
Well then I'll go the approach of replacing 4x 15's and/or 20's with tandems, and then get a double-50 as was recommended by others.. local hardware stores carry Square-D which I know many people often recommend..
thanks!
From what I gather, Siemens and Square D is a Ford/Chevy thing for some. Use whatever your panel requires as there are different styles. Pull an existing breaker and take it with you to be sure.
โSep-09-2019 10:09 AM
โSep-09-2019 08:21 AM
โSep-09-2019 08:15 AM
thanks!
โSep-09-2019 07:50 AM
โSep-09-2019 07:08 AM
โSep-09-2019 05:55 AM
wnjj wrote:
With that many normal sized breakers, it may be less expensive to tandem four of them into 2 slots and then install a standard 50 double pole breaker. Have you pulled a breaker to see if they will support tandems?
โSep-08-2019 07:30 PM
Gdetrailer wrote:
As far as the OPs setup, the only issue I see with the double breakers is many boxes which do accept those breakers do not have enough ground and Neutral buss bar connections. This may require doubling up on the ground and Neutral wires on the buss bars. Some electrical inspectors may be OK with that and some may not.
โSep-08-2019 07:28 PM
sayoung wrote:
I misunderstood where your dryer plug is, when you said on other side of garage I was visualizing 15 to 20 feet away. If those are GE-Homeline style breakers ( photo fuzzy ) , replacing with thins might be cheaper than the quad style. Lowes sales the GE Qline 30 & 50 dbl's for less than $10 ea. Thru the years the GE style "thins " gave me very little trouble and I' ve installed a many on the job , when I worked:B
โSep-08-2019 06:41 PM
โSep-08-2019 06:07 PM
โSep-08-2019 06:06 PM
stevemorris wrote:sayoung wrote:Learjet wrote:
As I said in post #2 do it right and add the circuit. The double 240 or if you have some single 120 CBs you can get those in double to make space for another standard 240 breaker. ๐
I had a thought , the 3rd wire on the dryer is not normally a current carrying wire but actually safety gnd so I wouldn't piggy-back these outlets. Maybe I was taught wrong years ago when gnd added to wireing code , was taught to never use the gnd for current carrying, it's there for protection.
this is incorrect. Both driers and stoves(household types) require the 120 as well as 240. Remove the neutral and they wont work. the control boards, clock, motors etc etc require 120, hence the neutral
