way2roll
Jul 07, 2022Navigator II
klutchdust wrote:enblethen wrote:
What antenna do you have?
Do you have in the wall power supply (booster)? Does if light up?
Make and model?
What is make and model of TT?
2015 Work and PlayUltra by Forest river. Second owner. TV that came with it did not have a remote. It's a brand that I have not heard of. The antenna looks like a flying saucer on a short pole. I travel solo fishing and attending desert racing events. I would like to have some reception of some kind even if it were some local news channel. As far as movies,netflix etc that is not important. There is a booster switch behind the TV . I have no problem replacing the TV and the antenna on the roof if necessary. Satellite TV I have no interest in.
So, what are my options. Having a TV is not a necessity but let's see whaat you guys come up with, thanks
If it's only local news you are after, streaming would be overkill. Add to that, many local channels don't stream anyway and if they do it's after the actual airing. Find a universal remote that works with your TV and scan the channels. that said, in the middle of nowhere you may have difficulty finding channels. You can always just get news on your phone.
BTW, you'll still need a remote for your TV even if you stream. At a minimum, power, channels, volume etc
