DrewE
Nov 19, 2019Explorer II
BFL13 wrote:
With the battery not there, collect all the wire terminals that go on its positive post and join them with vise grips or a nut and bolt.
Now the converter will have a path to the jacks. This assumes the jacks are on a different wire that goes to the positive post. Assumes the jacks and the converter each has a negative path to the frame.
Do take care if you do this that the vice grips or nut and bolt don't short out to the chassis of the RV!
