EstorilM
Aug 17, 2018Explorer
Using TT in sub-freezing temps/elect. What's required?
Hi everyone,
There's a possibility that I may need to use my TT for a month or two this fall when temps may fall below freezing (and for future reference, I'm curious about this in general).
The 2570RL has the arctic package and is fully enclosed, but I'm not sure exactly how much that helps in the real world.
My main issue is that I'll probably be running electric heat, which obviously bypasses all of the heat ducts underneath that likely keep everything well above freezing.
Has anyone just modified an electric ceramic-type heater into the existing floor ducting so that you can heat the interior while still bleeding enough heat off to keep the pipes from freezing? It's an RL so has 2 grey tanks, one for galley and one for the bathroom - the plumbing is rather spread out for its size.
