Tachdriver's avatar
Tachdriver
Valterra A01-1116VP Leaks
i have had this pressure regulator since 2013.
I accidentally left it in the trailer last winter and whatever water inside froze and the gauge stopped working, I ordered a new gauge and installed it and it worked great since then.
This last winter I brought the regulator in the house so it never froze. I hooked it up on the maiden voyage to de-winterize last month and now it is leaking around where the plastic meets the metal. :S
IS there a fix or am I doomed to get another one?. I cannot seem to change the pressure from the adjusting screw anymore.
  • I have not seen any and can't imagine I can do anything with the plastic side of the regulator
  • Let us know if you find a rebuild kit for the Valtera regulator.
  • Bobbo's avatar
    Bobbo
    I have destroyed several of the pressure gauges that way. I finally just plugged the hole where the pressure gauge goes. I have the WATTS regulator. I know nothing of any plastic on a regulator.
    I know there are rebuild kits for the WATTS, are there any for the Valterra?
