dennislanier's avatar
dennislanier
Voyager backup camera
After a lot of frustration and research, I finally have a working backup camera on my Class C. The camera stopped working last fall when I was having battery issues with the chassis battery. I think in the process of trying to start the MH with a weak battery and trying to use the aux battery in the coach, I must have killed the monitor. Anyway it has not worked for several months. I have tried various means to try and fix it to no avail.
I then ordered a new camera and monitor from Tadi Brothers, but after receiving it, I decided that it was too incompatible with my Voyager system. It would have involved multiple adapters, cutting and splicing wires and cables etc. Don't get me wrong. Tadi Brothers tried very hard to help me out but I did not want to do a complete "re-cable" nor did I want wireless if I could help it. I then googled "Voyager" and came up with "RVCAMERAS.COM". I gave them a call and they were very helpful in getting a new monitor to go with my 11 year old camera. It was basically a "plug and play" with only one adapter required.
Sorry for the long post but I just wanted to encourage anyone who might have problems with a Voyager system to call RVCams. Their customer service was outstanding and I am a satisfied customer. No, I do not have any ties with their company, just giving them a little support for their efforts.
  • C_B_'s avatar
    C_B_
    twotoes wrote:
    I just purchased a wireless camera system from them that was a lot less than the Voyager. Called their customer service to report that it was intermittently loosing the camera signal. They are sending me an external antenna for the camera at no cost. Hopefully his will correct the problem. Great customer service.
    You don't say how long your camper is. Mine is40'.
    I was having the same problem as you. RV Cams had me add the 80" antenna extension. IT helped but didn't totally cure the problem.
    Called RV Cams back and purchased the 30'antenna extension cable.
    Now my antenna is mounted on the front cap and I have not lost the signal.
    C.B.
  • I just purchased a wireless camera system from them that was a lot less than the Voyager. Called their customer service to report that it was intermittently loosing the camera signal. They are sending me an external antenna for the camera at no cost. Hopefully his will correct the problem. Great customer service.
  • I have never heard a complaint about them in all the years I have been on RV.NET. Many posts by satisfied customers. I bought my camera from RVCams in about 2005 or 2006. They were extremely helpful in educating me on cameras. There is lots to know to select the correct camera for your needs. They got it right for me.
    Wayne
  • Yes, rv.cams are the pros. One of the very few places that not only sells but services cameras and monitors.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
