rockcandymounta
Mar 09, 2021Explorer
water heater issue
2016 Dutchman Denali 5th Wheel.
I blow out all water lines to winterize my RV. So first trip out electric hot water not working at all and gas only getting warm not hot.
When I attached water to the rig, I started bleeding the air out of the lines and then remembered that I hadn't flipped the valve to fill the hot water tank. I did that, then turned on the hot water control on the kitchen and bathroom sink.
I am getting no hot water at all on the electric side and just warm water on the gas side.
The circuit breaker on the service panel is on.
I did a search for hot water issues and saw some talk about perhaps air being in the tank.
Also, I haven't run the bathtub faucet yet. When we get to our next destination, I may pull the plug in the tank, let it drain and refill it.
Will update in about 400 miles
