Old-Biscuit
Jul 20, 2019Explorer III
unclescratch wrote:
water heater wiring need help
I have a Suburban Model SW12DE w/both gas and electric heating. I want to move the outside (at the heater) rocker switch for the electric element to a more convenient inside switch. I have suburban's relay and the inside switch that controls both gas and electric. Question: Will the red signal light on the inside switch be used at all w/the electric heating element? I understand electric circuits pretty well, but where shall I ground the 12-volt signal wire exiting the relay? I will have to bench test the relay to determine which terminals are for 12 or 110 volts, unless someone can offer me a diagram? Thanks for whatever help you can offer ! :@
See FULL Description of 'MOD' using the DC Switches and DC Relay in your other post on that other RV Forum
Not going to repost here.
