Spade_Cooley's avatar
Spade_Cooley
Water miser issues.
I just bought a new Rockwood travel trailer with stall shower. It has a water miser set up in the shower with a stainless shut off valve under the knobs. The knobs turn goofy., opposite what normal valves turn. I want more pressure. In my old TT I switched the head out to another brand I can't remember what it was but it put out more pressure. I do have a pressure regulator that is a little bit larger than the restricted units recommended. Any ideas on how to modify this unit? What were they thinking
  • Howdy, I found the oxygenics a huge dissapointment. I re installed my original shower head. It had more reasonable flow. I did use the oxygenics shutoff valve immediatly before the shower head as it was better then the old one.
  • Not sure if your setup is like mine, but I was able to remove the head and replace it with one from Lowe's or Home Depot. You get the all the flow your water pump can provide. I also have 2 water pumps install so I get plenty of water!
  • Thanks,
    The Oxy system was the unit I put on my last trailer. I m not concerned about saving water if I am in an rv park and might even like to modify this unit if at all possible. I want a good flow. Or is there an even better unit on the market?
  • I used a Sharpie to mark how to turn the knobs in my TT shower ;(
    Oxygenics is the brand shower head that increases apparent water pressure flow.
Having RV issues? Connect with others who have been in your shoes.24,210 PostsLatest Activity: Mar 02, 2025
