jseyfert3
Oct 29, 2019Explorer
SoundGuy wrote:
Have you considered fresh water tank sag?
Obviously if the pump's intake hose doesn't draw from the lowest part of the tank the pump it can't pump that water. I had this problem with our Freedom Express and installed braces to support the tank and ensure the bottom was flat. I also moved the draw tube which was connected to a side port on the tank to the tank drain port which was on the bottom of the tank. Solved the problem entirely. :B
Wow, that's crazy they put that tank in there with no supports. The tank on ours is supported along both long sides with L-brackets, and has two cross bars between these side brackets to prevent sag. And the water pump draw tube was put on the bottom of the tank.
I guess we got lucky. With those two things we can drain our tank dry with the pump, provided we park the camper level.
