drwwicks
Jan 21, 2018Explorer
Prime Time Crusader ???
Looking for information about Prime time Crusader 5th wheel. We are looking at getting a 2012 bunkhouse model to use as most time "beach house", bayou actually, and occasional tow some place. If I get it the price will be real good, bank repo. I've looked it over a couple of times and it appears solid. No leaks or delamination evident. Floors solid but I'll check more thourghly. But haven't been able to check out the systems. Fellow I know has it stored at his lot for the CU and has winterized it for me. Before I'm obligated financially I can take to get checked out and since I have a pole barn with 50amp full hookups, that seems to be ideal place.
The air conditioner, single 15K unit on the roof is ducted with no ceiling plate. Prime time literature calls it "quiet" but manufacturers claims are dubious at best. In truth how noisy and effective is the air? The trailer has only one a/c so we'll likely add a second. Hopefully it will also tie into the ducting but not sure at this point. Dometic 8 cuft refer that smells a bit musty and somewhat rusty shelves from not used and closed up. Figure we can refinish them if the refer works.
Basically at the price we can get it we can afford to replace most of the appliances and come out ahead, but hopefully everything works. Girlfriend plans to paint the walls to cover the crappy wall paper, possibly paint white the cabinets, and later replace the bunk room carpet with sheet vinyl. Other furnishings may get replaced too, i.e. dining booth, couch. Almost guaranteed that the queen bed will get a new mattress. We both like a good night's sleep.
So for Crusader owners or others with direct knowledge, how is the build quality? What red flags should I look for that are unique to Prime time and Crusader? Appreciate any and all info good and bad that can be provided.
____________
____________
