QCMan
Jun 25, 2023Nomad III
The answer is that you have a leak in your water system someplace at or after the pump. The pump is trying to build pressure but it can't because the pressure is leaking out someplace. Start ar the pump and make sure all fittings are tight and keep an eye open for wet spots.
