JaycoAngel's avatar
JaycoAngel
Water softener
We purchased a water softener and a separate carbon water filter for outside our unit. Which hooks up to the water source first?
  • I would suggest the opposite.
    From personal experience I can tell you that if you put the carbon filter first it will plug up prematurely.
    8+ years full time I have experienced the nasty hard water full of calcium, iron and sulphur in Northern Arizona to water pumped from a creek in Washington taught me a lot about dealing with water quality issues.
    I would suggest that you reach out to Jesse at Waterfixers in Oregon. He is a sharp guy and can point you in the right direction.
  • FIRST AND ALWAYS FIRST!
    Comes a cleanable stainless wire mesh strainer element
    NEXT inline is a one-micron filter such as a ROTOPLAS cartridge filter.
    Then the R/O unit
    Next the UV or O3 sterilization
    And finally the charcoal.
    A charcoal filter is a harbor of bacteria
    And O3 sterilization is by far the preferred method of sterilization.
    Generally, you put a sediment filter first to keep the rocks out. It sounds like you're using the carbon filter as a sediment filter.
    Are you using one of those inline Camco filters? If so, they're a combo sediment/carbon filter.
  • I always used a particulate filter followed by carbon then the softener. The particulate filter needed changed most often but it was also the cheapest.
  • I use a sediment filter prior to the softener then a carbon filter after. My set up has the carbon filter in the RV, after the water pump and shore connection.
Having RV issues? Connect with others who have been in your shoes.24,187 PostsLatest Activity: Jan 14, 2025
