- MDKMDKExplorer
jjjandrbaker wrote:
MDKMDK wrote:
jjjandrbaker wrote:
The 53 is because December 31, 2017 was on a Sunday, therefore entering a 53rd week. Code numbers for the month range from 01-53 for that reason.
You just made that up??? :B
No. Actually Pope Gregory XIII introduced the calendar in the 1500s. I wasn't born until the 1950s.
He was one smart Pontiff, figuring out tire date codes back then. :B - jjjandrbakerExplorer
No. Actually Pope Gregory XIII introduced the calendar in the 1500s. I wasn't born until the 1950s. - parkmanaaExplorerRon3rd
"Date codes differ from mfg to mfg but the info above could be correct."
Beg to differ, sir. A portion of the DOT required alpha-numeric string can
be used by the tire manufacturer for his unique coding, however the last 4 digits must, by DOT rules for every tire requiring DOT marking sold in the USA, indicate week and year tire was manufactured. - MDKMDKExplorer
You just made that up??? :B - Ron3rdExplorer IIIDate codes differ from mfg to mfg but the info above could be correct.
- rk911Explorernew math
- joebedfordNomad III did not know that.
- larry_cadExplorer II
Wow!:) - jjjandrbakerExplorerThe 53 is because December 31, 2017 was on a Sunday, therefore entering a 53rd week. Code numbers for the month range from 01-53 for that reason.
- larry_cadExplorer IIGuess it means manufactured in the "53rd" week of 2017. Wonder what country it was made in? :h
Having RV issues? Connect with others who have been in your shoes.24,213 PostsLatest Activity: Mar 14, 2025
