You know that pwm doesn't control voltage so the top 2.6 volts on a 17 volt panel don't matter a hoot, assuming a 14.4 charging voltage. #10 wire is good for 30 amps. 280 watts/12.8 volts =~22 amps max.
If it were an MPPT controller then wire size matters big time. My personal choice was and would be MPPT with a series connection for the panels.
