tarnold
Feb 13, 2017Explorer
What size fuse
Going to add a 1000 watt pure sine wave inverter. Want to install a ANL fuse between inverter and battery. What size fuse should I use? Will be nothing more than Cpap machine or tv.
kellertx5er wrote:Ok I do assume quality marine wire with 105C insulation not bundled.time2roll wrote:
Assuming #4 or #2 wire I would be about 125 to 150 amps.
If you are going smaller on the wire the fuse would need to be reduced.
Neither #4 (85A) or #2(115A) will safely carry 125 amps.
What does the mfg. recommend?
