Gdetrailer
Mar 15, 2022Explorer III
valhalla360 wrote:Lwiddis wrote:
A Jackery is about as an expensive solution as you could find. (It’s a battery!) Add another solar panel and another RV deep cycle battery. Consider Lithium.
From his description, he has plenty of solar and battery already. He just needs a way to convert that into something that will run the clippers.
It would be silly for him to spend a ton of money building a system that he doesn't need.
The rechargeable clippers should take care of the issue...and simply plug them in and see if they charge off the cheap inverter (don't leave the inverter running all the time). Otherwise, charge them when you are on shore power.
Sometimes it is the simple low cost solutions that work the best. Rechargeable battery powered clippers? Yep, solves that problem.. Should be able to get multiple uses before needing recharged.
