Rycher's avatar
Rycher
What System panel do i have?
I cant find any info on this thing. anyone seen this before and know the manufacturer?
  • just fyi for all.. i was able to pull it out far enough to see its a geckotech model ecp. very similar to the KIB's on the market..
  • Might be able to take the screws out and pull it out far enough to see if there is amfg and moder number. Worse case might need a flashlight and or mirror.
  • 3 tons wrote:
    Dusty R wrote:
    Not what you are asking, but check out "Sea Level" tank sensors. A much better system given levels in %. And not very hard to install.
    Actually, ‘SeeLevel’ by Garnet.
    Good catch, thanks.
  • 3_tons's avatar
    3_tons
  • Not what you are asking, but check out "Sea Level" tank sensors. A much better system given levels in %. And not very hard to install.
  • I would take out those two screws, and remove the device so I could look at what is on the back. Probably a manufacturer name and model number.
Having RV issues? Connect with others who have been in your shoes.24,198 PostsLatest Activity: Feb 12, 2025
