Any recently purchased commercially available axle grease that is approved for your application is fine. Some are better. No grease will perform well if it gets contaminated, if the bearings are overloaded, or incorrectly adjusted.
For the most part, if you follow the recommendation(s) in the appropriate manual, . . . . . . you'll be fine. Clean the bearings, repack/change the grease according to your owners manual or if you KNOW the bearings have been contaminated.
Read the published specs for your application and ignore the salesperson/internet.
Chum lee
