MEXICOWANDERER's avatar
Dec 07, 2018
WHEN I ASKED LIFELINE ABOUT THEIR GOLF CAR BATTERIES
In relationship to say their 8-D battery, this is the answer I got...
Justin Godber
12:48 PM (0 minutes ago)
to me
When you talk about 1 battery vs. 2 six volts there is no advantage or disadvantage either way. The only advantage is the 6 volts are much easier to move around by yourself.
When you get into a 6 or 8 battery bank of six volts you can physically get more amp hour into the same space as the 8D’s using 6 volts. Example for the GPL-4CT, you can fit 3 in the place of 1 x 8D. If you had 2 x 8D’s you could fit 6 x GPL-4CT’s. GPL-4CT x 6 is 660 amp hour whereas 2 of the 8D’s would be 510 amp hour within the same footprint.
I knew this twenty years ago. But the superstition about "Golf Car" being a better battery somehow, just will not disappear.
The FOOTPRINT may be the deciding factor for many people. But as far as plates and general construction goes, choosing a 3-cell battery doubles the number of series cables needed
Nuff Said
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 24, 2025
