Jackutah's avatar
Jackutah
Where is chassis fuses 1993 itasca sunrise ww/ Chevy 454 gas
A helpful neighbor was trying to see why the switch to power the radio from aux battery didn't work..found wires and well...the radio stopped getting power.. I hope it is fuse .. I looked online and everywhere says the fuses for chassis are under hood on driver side but there is nothing there...
Can anyone help me find these so I can check fuses.. And then try figure why radio won't get power from aux battery when toggle switch positioned
  • Chev chassis fuse block is located under the dash to the right of the steering column.
    However any radio fuses both main and aux power comes from the battery control center. This should be under the hood driver's side.
    There should be one fuse for constant power and one fuse for main (chassis) and one from the aux (house) battery system
  • The dashboard in front of steering wheel is hinged. Lift and you will see the fuses. Bill
  • If this is a class A
    Goto Winnebago.com , they have manuals and schematics online
    If this is a class C
    Look under the dash on the drivers side
    Outside under the hood, it will have a plastic cover over it, the cover is probably Not Labeled
Having RV issues? Connect with others who have been in your shoes.24,351 PostsLatest Activity: Jan 19, 2026
