- mike-sExplorer
time2roll wrote:
If your hubs are getting that hot, you're doing it wrong.
mobile 1 goes on mine for the highest dropping point spec. - amxpressExplorerI’m a strong believer in using a quality synthetic grease.
Amsoil Synthetic Grease - Mortimer_BrewstExplorer III use Mystic JT-6 Hi-Temp #2. I can get it in both a tube and a tub, so I don’t have to worry about incompatibility. It’s also Dexter approved.
- fj12ryderExplorer IIIMine is pretty much whatever is in the grease gun at the time.
- mobile 1 goes on mine for the highest dropping point spec.
- mike-sExplorerI just use the Valvoline red grease from my FLAPS. It's a lithium soap, I think.
- azdryheatExplorerMy Chinese made bearings don't seem to care about the grease. I use a grease made for wheel bearings but not the high temp kind of grease.
- BB_TXNomadLithium has proven itself. But main thing is make sure you do not mix grease types.
- Iraqvet05ExplorerWho makes your axles? Dexter has a recommended list of grease on their website and Lippert may too.
- LwiddisExplorer IIIf you repack yearly, a good practice, either will do IMO.
Having RV issues? Connect with others who have been in your shoes.24,211 PostsLatest Activity: Mar 08, 2025
