MEXICOWANDERER
Jul 15, 2019Explorer
Even though the decision has been made, a lot of weight has to be thrown at two areas.
For example, if your batteries are AGM, you cycle them on vacation, return home then connect them you a WFCO their lifespan will be short and ugly
Connect wet batteries to a WFCO they'll end up sulfated and useless.
It's either yes or no, can the converter recharge to batteries be recharged to 100% in a reasonable amount of time before they sulfate?
Like anything else to do with batteries, the answer does not come easily. The longer they spend under-charged, the deeper the cycling makes all the difference in the world.
Batteries that endure shallow cycling, fare better. Batteries that endure less time partially charged fare better.
Batteries that endure don't give a **** ignorance also endure no mid-life crisis because they are dead,
Batteries demand a full charge periodically. Perhaps lithium chemistry is different. But <1% of RV'ers have lithium batteries.
Recharge batteries properly and it would be very usual to enjoy a 300% gain in lifespan.
There is NO question that obeying the demands of AGM battery recharging to 100% full is significantly easier as compared to any flooded battery. Controlled voltage and the presence of a panel voltmeter and ammeter are necessary. Intelligence choosing the correct mixture of generator and solar is also necessary to gain full benefit.
Sizing the battery bank to gain a full advantage is also demanded. The compromise is weight.
- Your vacation type. How you spend or not vacations away from a power pedestal
- How fast your converter can recover the batteries when connected to a power pedestal
