โJun-24-2015 02:25 PM
โJun-27-2015 02:39 PM
โJun-27-2015 10:58 AM
pianotuna wrote:
This looks interesting--a combo inverter/charger/solar controller.
inverter charger and solar controller It can accept 30 amps on the solar side.
โJun-27-2015 10:02 AM
โJun-27-2015 09:51 AM
โJun-27-2015 09:34 AM
โJun-27-2015 09:30 AM
โJun-27-2015 09:26 AM
โJun-27-2015 09:25 AM
โJun-27-2015 08:47 AM
โJun-26-2015 10:46 PM
smkettner wrote:
Yes this is on p8 of the TS MPPT manual:
To comply with the National Electric Code (NEC), the current rating of the controller must be
equal to or greater than 125% of the solar arrayโs short circuit current output (Isc). Therefore, the
maximum allowable solar array input to the TriStar MPPT 150V controller for compliance with the
NEC is:
TS-MPPT-30: 24 amps Isc*
TS-MPPT-45: 36 amps Isc*
TS-MPPT-60: 48 amps Isc* *Solar array Isc @ STC
My array Isc is about 8 amps and 675 watts. Maybe another reason to go series.
TS MPPT manual
โJun-26-2015 10:40 PM
Empty Nest, Soon wrote:
I have not looked that much at cheaper controllers, but the lack of a heat sink is one obvious difference. And yes, providing a heat sink at a reasonable cost should be easy. I canโt explain why the market has not offered that.
But how about a Tri-star 45 for $161? http://www.ebay.com/itm/221681616399?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Wayne
โJun-26-2015 10:22 PM
โJun-26-2015 09:11 PM
โJun-26-2015 08:55 PM
To comply with the National Electric Code (NEC), the current rating of the controller for solar charging must be equal or greater than 125% of the solar arrayโs short circuit current output (Isc). Therefore, the maximum allowable solar array input to the TriStar controller for compliance with the NEC is:
TS-45: 36 amps Isc
TS-60: 48 amps Isc
