jodeb720
Aug 25, 2019Explorer
Folks, I think there's some confusion here.
If this is for the Potable Water system in his RV, then the $2.58 should be used.
If it's for the engine in his RV (truck/car) then the 15.00 one should be used.
NEVER PUT THE $15.00 AntiFreeze in the RV Water System. It's poison and will make you very very ill if you drink the water after it's in the system!!!!
The "Pink" stuff is what's used in RV's to insure the pipes don't burst from freezing during the winter.
Josh
Josh
Having RV issues? Connect with others who have been in your shoes.24,192 PostsLatest Activity: Jan 26, 2025
